Hotpoint UY46 bottem oven not working
Home Forums Public Support Forums Help And Support Cooker And Oven Forum Hotpoint UY46 bottem oven not working
  • #32136
    skeep
    hi all,
    THis is my first post so i hope you can help! I have a hotpoint UY46 double oven and after a recent powercut the bottom oven has stoped working.
    After searching the forums i came across this post:
    viewtopic.php?f=33&t=18475
    However, setting the time has not helped.
    It is the bottom oven that is not heating up however, the fan and light both seem to fine. In addition, the top oven is working fine!
    I hope someone out there can point me in the right direction!
    Skeep
    #233740
    Re: Hotpoint UY46 bottem oven not working
    Fan oven element has probably failed and can be found here:
    http://shop.ukwhitegoods.co.uk/Cooker+{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} … ement.html
    Some good info on fan oven elements can be found here:
    http://www.ukwhitegoods.co.uk/help/fix- … notes.html
    Power off if you intend to do this yourself.
    skeep
    Thanks for getting back to me.
    Is this an easy job for me to do or am i better of getting someone in. The article points to a couple of warnings will these apply to the UY46?
    #233742
    Not difficult, a screwdriver job basically. The hardest part is getting the back panel to come off.
    The warnings are pretty general, observe power precautions carefully.
    kiddo66
    You dont have to take the back panel off there is enough length on the cables to do it from inside the oven cavity,just take it easy and you will manage it no probs.
    #233744
    You can’t access the element if you don’t take the back panel off – it’s behind it.
    kiddo66
    Ahhh you meant the oven liner back panel……
    #233746
    kiddo66 wrote:Ahhh you meant the oven liner back panel……
    And in official Hotpoint terminology it’s known as a FAN OVEN INNER PANEL 😉
