Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Hotpoint Vented Dryer TVFS83CGP(UK) – TOC Activated again after replacing
- This topic has 4 replies, 2 voices, and was last updated 2 years ago by
neon_3SP_glow.
April 4, 2024 at 4:28 pm #102686
neon_3SP_glow
ParticipantHOTPOINT Vented Tumble Dryer
Mod. TVFS83CGP(UK)
Ind. 95859720100
Sn. 606200651Was called to this vented dryer a week or two back. The Thermal Overheat Cutout (Orange spot, situated on top of heater box) was open circuit.
The machine had an extremely crushed Vent hose and I presumed that this was causing a blockage of airflow and that had caused the TOC to go open circuit. Subsequently replaced the vent hose and these thermostats (Tumble Dryer Thermostat J00114433 – Hotpoint – Hotpoint). Tested the machine and everything was working fine. Air flow was great and it was heating.
Customer used the machine three times since (each time on a timed dry program) and now the TOC has failed again. They have assured me that they did not overload the machine and that the vent hose was not kinked or obstructed and that the door filter was cleaned prior to use. Upon visit earlier today, again, the airflow was great, no blockages etc.
Please can someone explain to me what the NTC is used for? The heatbox has two old style thermostats either side of the NTC type. Blue spot on the LHS, NTC in the middle, Orange spot on the RHS.
Is it possible for the NTC to be faulty causing the machine to overheat and fail the Orange spot TOC.
Also, is the Bluespot a cycling stat or another TOC used for fail safe redundancy?
ANy ideas would be greatly appreciated. Thanks.
April 4, 2024 at 8:51 pm #490038electrofix
Moderatorhave you had a close look at the elements to see if any of them can short or bunch up causing hot spots
April 4, 2024 at 9:00 pm #490039electrofix
Moderatorfound service manual and emailed it to you
April 4, 2024 at 11:23 pm #490040neon_3SP_glow
ParticipantThank you Dave, very insightful.
April 15, 2024 at 5:27 pm #490041neon_3SP_glow
ParticipantUpdate:
Element was fine. Both NTC’s checked out at room temp ok.
No airflow issues.
I wonder if customers accidentally covered inlet vents behind the lid.
Fitted new cycling stat and TOC, all seemed fine.
Cheers
