Hotpoint vented tumble dryer not spinning
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Hotpoint vented tumble dryer not spinning
  • #26854
    adr0ck
    i have approx 18 month old hotpoint vented tumble dryer which has stopped spinning – hot air still comes out, barrel wont spin
    anyone got any ideas of where i can start?
    thanks in advance
    #211629
    petalpop
    Re: Hotpoint vented tumble dryer not spinning
    first UNPLUG
    then remove lid and you should see a black band(belt) around the drum
    if not the belt has snapped and you need a new one
    #211630
    adr0ck
    thanks…i’ll try that tonight and report back tomorrow
    thank you
    #211631
    adr0ck
    the belt has snapped and i need a new one!!!
    where do i get a new one and how do i fit it?
    the make is Hotpoint Aquarius VTD00 Reverse Action 6KG
    thanks
    #211632
    You can order a new belt from spares@ukwhitegoods.co.uk , however I doubt that you will be able to refit it without a major struggle.
    The belt is a very tight ‘stretchy’ belt and several of us in the trade use a special tool to refit the belt.
    adr0ck
    thanks for the reply
    should i order a belt off ukwhitegoods and then find an engineer around my way to fit it?
    could you tell me how much an engineer would charge?
    also how much does this special tool would cost?
    #211634
    Special tool is around £30.00. Several engineers have their own methods that work for them but either way it is a difficult job without the correct equipment.
    You could always contact a local engineer, most reputable people will be happy to discuss your problem and give you a fairly accurate estimate for this type of job. Also most of them will carry this part or have speedy access to one.
