Hotpoint VTD00 Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Hotpoint VTD00 This topic has 7 replies, 4 voices, and was last updated 17 years, 7 months ago by mjhservices. Viewing 8 posts - 1 through 8 (of 8 total) Author Posts September 10, 2008 at 2:36 pm #39375 mjhservicesParticipant Does anyone know how to change the inner door on a Hotpoint VTD00 I know this sounds mad but it seems as if the the hinge is moulded into the inner door and can not be changed. Mark. September 10, 2008 at 2:47 pm #262270 MartinParticipant Re: Hotpoint VTD00 It’s just a 2 part door held together with 6 screws. 😉 September 10, 2008 at 2:57 pm #262271 mjhservicesParticipant Re: Hotpoint VTD00 Thanks for your reply but the problem is separating the inner door from the hinge. September 10, 2008 at 3:12 pm #262272 MartinParticipant Re: Hotpoint VTD00 The hinges and door inner are sold separately with the hinge pivots locking into the frame as a push fit and not screwed. September 10, 2008 at 4:10 pm #262273 mjhservicesParticipant Re: Hotpoint VTD00 Hi Martin There is no way this inner door is a push fit into the hinge. Myself and others can not see how this is possible. Mark September 10, 2008 at 4:36 pm #262274 helo_75Participant honestly, if you move the hinge to the closed position, it will slide down and pull out look at it, its really obvious September 10, 2008 at 4:37 pm #262275 helo_75Participant one side of the hinge pin , on the trim, is moulded closed, the other open , i reslly dont see how your struggling tbh…… September 11, 2008 at 11:54 am #262276 MDEParticipant helo_75 wrote: if you move the hinge to the closed position, it will slide down and pull out Hinges must be removed from the body of the machine. Then replace as above. Author Posts Viewing 8 posts - 1 through 8 (of 8 total) You must be logged in to reply to this topic. Log In Username: Password: Keep me signed in Log In
