Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › Hotpoint VTD00 Dryer won’t stay on
- This topic has 8 replies, 2 voices, and was last updated 16 years, 10 months ago by
incubroz.
June 22, 2009 at 8:02 pm #46558
incubroz
ParticipantHi all.
I have bought a second-hand Hotpoint Aquarius VTD00 Tumble Dryer on the understanding that it was in full working condition but this is not the case. I can’t afford to get it fixed professionally or replaced so I’m hoping you can help.The problem I have is that when I press Start, the drum starts to spin and as far as I can tell, everything works as it should. However, when I take my finger from the Start button, it stops. This happens whether it is set to Low or High heat.
In terms of the problem, it’s hard to give you any more detail than that but please ask if you need anything clearing up.
June 22, 2009 at 8:32 pm #289964Penguin45
ParticipantRe: Hotpoint VTD00 Dryer won’t stay on
Latching relay isn’t – you need one of THESE.
Power off if you are tackling this yourself.
June 22, 2009 at 8:40 pm #289965incubroz
Excellent. Thanks for the reply.
June 26, 2009 at 8:04 pm #289966incubroz
Well I have the part you suggested so unplugged the dryer from the mains and removed some panels (top, front, rhs) hoping to see the old Start Relay in there. I figured if I could locate it, all I would have to do is connect everything to the replacement in the same order and that would be it.
As it happens, I can’t see the current part anywhere!Can anyone tell me where the Start Relay is likely to be positioned in the machine?
Should it look similar to the replacement part or is that just a generic part that can be used in a several machines, simply wired slightly differently?
June 26, 2009 at 8:23 pm #289967Penguin45
That’s strange….. It’s listed for that machine in the shop@ section. It should be sitting behind the control panel, under the metal top rail.
June 26, 2009 at 8:26 pm #289968incubroz
It is listed a being for my dryer but there’s definitely not one behind the control panel and I can’t see one anywhere else :hmm:
June 26, 2009 at 8:27 pm #289969Penguin45
Oh…….. Later versions went on to a relay pcb board – is there a small pcb located as described above?
June 26, 2009 at 8:29 pm #289970incubroz
Yeah, I have the wrong part then??
June 26, 2009 at 8:38 pm #289971Penguin45
Dangnabit! Right, you need C00207999. It doesn’t show in the shop, so drop Dave an email on spares@ukwhitegoods.co.uk with that part number and explain what’s happened (or a link to this thread). It’ll get sorted promptly for you.
Apologies,
Penguin45. -
