Home › Forums › Trade Technical & Spare Parts Forums › Trade Spare Parts › hotpoint vtd00 pulley
- This topic has 10 replies, 6 voices, and was last updated 19 years, 2 months ago by
cornwell40.
January 25, 2007 at 9:26 pm #24503
cornwell40
ParticipantI’m after the pulley wheel on this dryer. Has completely collapsed due to the tension on it I reckon. Anyone know the number for it?
Tony cJanuary 25, 2007 at 9:30 pm #202324helo_75
ParticipantRe: hotpoint vtd00 pulley
think ll find its a ctd00p matey
trust me
January 25, 2007 at 9:40 pm #202325cornwell40
OOps 😳
It is CTDoop.
Looking at the wrong call.
Thanks for that.
Tony cJanuary 26, 2007 at 12:24 am #202326Penguin45
1702973
January 26, 2007 at 12:38 am #202327helo_75
thats the one!!
cheers penguin, now the fun starts
use an old belt to pull the belt over the new pulley
readin other sections, people have been struggling a little.. they are tight
make sure ur hands are protected, its tight, and if u slip.. ouch
January 26, 2007 at 12:41 am #202328Penguin45
Just pivot the pulley on the inboard screw, then lever it down with the belt around it and catch the second screw on its thread. Doddle.
January 26, 2007 at 9:54 am #202329cornwell40
Ta gents.
This pulley seems a little…er…flimsy to carry the tension don’t it.
What are they thinking about with these direct drive arrangements when the pulleys were fine for years. A spray of wd40 😉 every now and then and they were ok for years.
I think Indypoint should buy Costcutters out too , it would be more bl**dy apt 👿Tony C
February 12, 2007 at 10:30 pm #202330bruce118
If you have a X245677 jockey pulley, this will fit, I have removed the pulley + fitted it to a CTD00P- pulley identical.
February 12, 2007 at 11:09 pm #202331iadom
ModeratorRe: hotpoint vtd00 pulley
Penguin45 wrote:Just pivot the pulley on the inboard screw, then lever it down with the belt around it and catch the second screw on its thread. Doddle.
Thought about this when I did a belt change on one of these last week. The pulley bracket will not pivot on the machine I did, it has two screws either end but is hooked under the motor casing in the middle as well,so will not come upwards away from the motor if you only remove the nearest screw.Jim.
February 13, 2007 at 12:04 am #202332Penguin45
Yes, you have to slacken the inboard one enough to let it move. It does work and you don’t even need some damn non-available special tool. 😀
February 13, 2007 at 7:26 pm #202333HotDog
Going back to the early vented hotpoint dryer TL range these were the first direct drive models still have slots in base to fit jockey/arm change belt to 1700442 bingo back to a brilliant dryer
