Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › Hotpoint VTD00 Tumble Dryer – oil stains
- This topic has 11 replies, 4 voices, and was last updated 17 years, 8 months ago by
GillyDee.
August 12, 2008 at 11:27 am #38694
GillyDee
ParticipantHave noticed what look like clear oil stains on clothes/sheets which have been through the dryer. Feel a bit of a dork actually 😳 it’s taken me ages to work out that it’s the dryer after I put some new pillow cases in and they came out streaky………
Can’t feel anything greasy inside the dryer – any ideas?
August 12, 2008 at 1:09 pm #259673Chriztopher
ParticipantRe: Hotpoint VTD00 Tumble Dryer – oil stains
Do you use tumble dryer sheets and if so do you put in more than one at a time?
My wife used to use the “tesco moist dryer sheets” and used three at a time to make things smell better :rolls: ….. started getting streaky marks.
Dropped to the recommended one sheet and the marks stopped.
Hope this helps 😉Chris
August 12, 2008 at 2:44 pm #259674GillyDee
Thanks for the reply, Chris.
I sometimes use Bounce sheets, but only one at a time – I never noticed a similar problem in my old Hotpoint.
August 12, 2008 at 6:13 pm #259675helo_75
Participantgive over………..
itll need a shaft kit
p/no 1703080 available from online shop… the front felts come off, and snags the clothes
August 22, 2008 at 1:45 pm #259676GillyDee
OMG – does it come with a manual with big pictures 😕
August 22, 2008 at 8:25 pm #259677helo_75
Participantit does come with a leaflet, explaining what to do………
August 23, 2008 at 5:21 pm #259678GillyDee
Many thanks – I’ll give that a go.
August 23, 2008 at 5:29 pm #259679helo_75
Participantwhere in the world are you?
August 23, 2008 at 10:03 pm #259680GillyDee
Why? Do you suspect Planet Zog?
btw – gi o’er were a bit of a giveaway…
August 23, 2008 at 10:35 pm #259681helo_75
Participantthat could be anywhere from bolton to wigan, through to yerkshire
sheesh
August 23, 2008 at 11:26 pm #259682Penguin45
Now then…….
If this very noisy dryer is even more noisy than normal (grating. grumbling, scraping, banging), the shaft may well have sheared off the back of the drum.
It is worth considering that the drum fits in the casing and its’ seals so badly, that large amounts of fluff accumulates in the back of the drum. This will periodically burn and blow into the drum, causing black marks.
Just changing the shaft may not solve the basic problem.
Tha’ noes, lass.
August 24, 2008 at 8:19 am #259683helo_75
Participantthe kit mr penguin…. the front and rear seal will need changin of course, and the machine will need a GOOD clean while its apart to ensure safe and correct function, thats why i recommended the kit, not just the shaft
