Re: Hotpoint VTD20 T/dryer
Hi – I discounted the door lock as when the door is shut the ‘active’ light comes on, the timer runs and the heater comes on.
I went to this machine again to check the motor as she said she had smelled burning. When i tried it the machine worked ok for a while, i twiddled with the timer for a while and eventually it went off.
The symptoms are similar to the relay problems where the relay dropped out after running a while. Do these new modules suffer from similar problems?
My gut feeling is still the timer as the machine would not start at all last time. This would seem to rule out the relay module as i stopped and started it quite a few times before it went off on the last visit.
Andy 😀
