Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Hotpoint VTD20 tumble drier.
- This topic has 13 replies, 11 voices, and was last updated 17 years, 2 months ago by
ChrisR.
February 5, 2009 at 7:52 pm #43192
ChrisR
ParticipantHi guys.
Can somebody tell me how to change a drive belt on this model.
Thanks very much.Chris. 😕
February 5, 2009 at 8:04 pm #276347bazza500
ParticipantRe: Hotpoint VTD20 tumble drier.
Lid off, Control panel off, Front panel off, Belt round drum, Pull like F&*^{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d}, Get first aid kit, bandage hands and rebuild.
February 5, 2009 at 8:15 pm #276348johnnyj
Remove top cover, then remove right hand side panel remove console panel, push front panel outwards slip belt ond drum secure front panel and console, get the biggest screwdriver you can find and strecth belt via motor pulley with the screwdriver, turn drum while guiding belt onto pulley refit side panel and top cover, 10 mins should do it. JJ
February 5, 2009 at 9:32 pm #276349kiddo66
And another one.
Top off
right hand side panel off
remove three screws from back of left hand side panel
put your foot in the belt and pull (bullworker style)with your hands to stretch the belt a bit
pull the drum away from the front support and slip the belt on
put the screw back in the left hand panel
BIG screw driver and lever the belt onto the motor shaft.
Easy.February 5, 2009 at 9:40 pm #276350A1engineer
instead of a big screwdriver i use a extending bar with a big socket loop through belt and push socket into motor shaft, pull down and work belt off bar and onto motor.
kev
or use the hotpoint belt tool which is essentiallty the same,
February 6, 2009 at 12:18 am #276351Penguin45
A1engineer wrote:use the hotpoint belt tool which is essentiallty the same,
Part No: 5600266 if you want one?:DChris.
February 6, 2009 at 12:53 pm #276352pup
A1engineer wrote:instead of a big screwdriver i use a extending bar with a big socket loop through belt and push socket into motor shaft, pull down and work belt off bar and onto motor.
kev
i use copper pipe works well
February 6, 2009 at 5:04 pm #276353A1phil
I use a short piece of copper tube ,though belt over motor shaft pull down push belt onto shaft. Bit cheaper than the hotpoint tool.
February 6, 2009 at 6:59 pm #276354johnnyj
Chris i have the correct belt tool but never use it nowadays as it doesnt fit in my toolbox and a screwdriver never lets me down. jj
February 7, 2009 at 10:14 pm #276355ChrisR
Thanks guys.
As ever you`ve been very obliging 😀
February 10, 2009 at 7:09 pm #276356Micky 32
kiddo66 wrote:And another one.
Even though it does make it easier be careful not to do too much force or the belt will snap like what happened me a few months back 😳
I use the large screwdriver method.
February 13, 2009 at 11:51 am #276357wilf
the proper tool will pay for its self in no time. it also looks better if the customer is watching
wilf
February 13, 2009 at 2:07 pm #276358Micky 32
wilf wrote:the proper tool will pay for its self in no time. it also looks better if the customer is watching
wilf
True, doesn’t look good when you’re cursing and hitting the side of the appliance with a hammer in frustration 😆
February 13, 2009 at 2:45 pm #276359Martin
ChrisR wrote:Thanks guys.
We’ve only got to hope ChrisR didn’t attempt the repair today of all days? (Friday 13th that is) 😈
