Hi everyone,
A friend has a new Hotpoint VTD20 which is now out or warranty, when its turned on the drum turns anticlockwise and the heater does its normal thing.
The problem is when the timer turns and it hits the reverse cycle the drum stops and the heater continues to heat causing the drum to get very hot.
I have replaced the timer as I thought this was going to be the problem, so I am now thinking its either some fault on the motor itself (although I doubt it) or its the timer PCB mounted on the control panel.
Help much appreciated !
thanks
Rich
