The rear shaft has sheared off the drum on this machine, it has also cut through the Polypenco rear bearing and broken the belt. The tub front seal has been cut as well. As this one appears to run on the rollers at the front, what do I need to order to sort out the mess?
Spooky or what? Today my first call, VTD00P that I thought (speaking to my customer on the phone) was just like a broken belt required? I get there to find the drum shaft has collapsed, ripped into the back panel taking chunks out of the vents and the foam seal etc etc, what a bl**dy mess!!
Only 13 months old this heap of cr&p is too 🙄 Looks like I need a good van stock of bits for these machines, lovely jubbly 😀
