HOTPOINT VTD60
  • #89835
    tonyb68
    Can anybody tell me what the resistance readings for the thermistor in the exit vent tube should be at room temperature?
    The thermistor is working giving different values at various temperatures.
    Both of the thermostats above the heater have been replaced and the machine now says it is over heating error code 13.
    I am a bit reluctant to buy a new thermistor and find the fault it elsewhere….
    Thanks in advance.
    #442703
    Re: HOTPOINT VTD60
    This machine is subject to the fire safety ‘recall’ has it had the modifications done?
    #442704
    tonyb68
    Re: HOTPOINT VTD60
    Hi, no I don’t think it has.
    Thanks Tony.
    #442705
    Re: HOTPOINT VTD60
    Then you get it registered as soon as possible here.
    https://safety.hotpoint.eu/
    #442706
    tonyb68
    Re: HOTPOINT VTD60
    There is not much point in me registering, as it is not working properly, if I can sort out this problem with the thermistor I will register it.
    Do you know anything about the thermistor resistance values?
    #442707
    aqualectric
    Re: HOTPOINT VTD60
    Tony – yes we do know how the thermistor works…… the resistance value drops as the drier gets hotter. But you have to take seriously what Jim is saying – register it as faulty as the machine is subject to a safety recall that mustn’t be ignored. These machines can and do catch fire! If the drier is showing an overheat fault and in the light of what has been said, that should be enough for you to quit while you’re ahead. Hotpoint will offer you a modification for free or a brand new drier in a box delivered for £59.
    Why would you bother to try and fix it? Your house insurance and moreover your family won’t thank you if God forbid the worst happens. Especially if you are the last person to repair it………
    #442708
    tonyb68
    Re: HOTPOINT VTD60
    Point taken, thanks for every one help, next stop Hotpoint helpline.
