Hotpoint VTD60 t/dryer
  • #54510
    robbra
    wherever the selector is :-
    top lights 2,3,4,5 flash
    Side lights 3 & 4 flash and display shows 1h 55m
    and a beep.
    It also switches itself on. There are 2 stats and a sensor?? (which has no reading) above the heater.
    Any clues for please?
    Rob
    #319863
    Re: Hotpoint VTD60 t/dryer
    When you say no reading, its an NTC so its resistance will vary with temperature.
    All those lights flashing sounds like a PCB fault though. I wonder if these boards have the same capacitor fault that the washer PCB’s have?
    #319864
    robbra
    Thanks Jim,
    It was o/c but I’ve never seen one before on a Hotpoint dryer.
    I agree about the PCB but suppose I needed a backup.
    Rob
    #319865
    Are you sure it was O/C, I got fooled the very first time I tested one using a simple continuity test thinking it was a stat. 😉
    If you like I can send you a little something. 🙂
    It might be worth having a look at the tops of the capacitors on the PCB to see if any have ‘domed’.
    #319866
    robbra
    It’s ok Jim, the customer decided to get a White Knight as she has had problems with it for two years before they called me. Makes me wonder why they rang me in the first place.
