hotpoint vtd66 or 60 t/dryer
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries hotpoint vtd66 or 60 t/dryer
  • #36450
    tedd
    hi,went to machine today havent seen this model before,select programme and filter light stays on and does not start.customer says f7 and f10 has come up.any help,regards tedd
    #251008
    boselecta
    Re: hotpoint vtd66 or 60 t/dryer
    F10 ‘Common or heater open, one shot stat open circuit’
    F07 ‘not used, active’
    this is as the codes are listed in the UKwhitegoods Fault code guide
    #251009
    johnnyj
    F07 Lower element failure check element and wiring if okay looking like the module cheers, just a thought does it have a sensing band on the drum if so check the insulator under it, they shrink throwing up intermitant F10’s etc cheers JJ.
