Hotpoint washer BHWM149 – stopped after 10 mins
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Hotpoint washer BHWM149 – stopped after 10 mins
  • #93558
    twicknix
    This washer left me feeling stumped, it’s 18 months old,
    on quick wash program it fills then agitates for 10 minutes, until I think getting to drain prior to rinsing but it simply stopped. All lights came on.
    The drain pump is fine, no issues.
    I am thinking pcb module being the culprit? would the customer be better off contacting Hotpoint to claim under the 10 years parts guarantee instead of me removing the module and send away to EMW for repair? How much is the call out charge from Hotpoint for an 18 months old washer?
    #454794
    timdowning
    Re: Hotpoint washer BHWM149 – stopped after 10 mins
    Is the heater ok?
    Does it drain & spin ok as a separate cycle?
    #454795
    if you have the commercial code I may be able to dig something up
    the original machine with this model was made 2008 so I assume those details may be out of date if its only 18 month old
    twicknix
    timdowning wrote:Is the heater ok?
    Yes it does
    #454797
    twicknix
    electrofix wrote:if you have the commercial code I may be able to dig something up
    Will have a look and post later
    #454798
    twicknix
    The machine in question is BHWM 149 uk/2, S/N 610134798, COD 61021180000
    #454799
    not a lot of info due to the fact the unit fault codes are read by a reader. Have found lists of fault codes but you have no way of knowing if one is being displayed
    one thing that did pop up was
    included the pressure switch one because you may not realise its faulting out
    may or may not help
    twicknix
    Thank you. Will contact customer and see if it is a simple fix.
    #454801
    twicknix
    The weird thing is that the module was fried by a slug. Customer asked if this would be covered by the Hotpoint “ten years free parts” guarantee.
    I explained that this kind of thing is kinda out of Hotpoint’s control as it is not their fault that a slug took a liking to the board thus frying it in the process. In short answer that would be a no, unless I am wrong, please correct me.
    I have sent it off to EMW in the vain hope that they can repair or exchange.
