Hotpoint washer/drye, pump blocked cleared now will not fill
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Hotpoint washer/drye, pump blocked cleared now will not fill
  • #9737
    Problem as stated above,
    Does an O/C pump, break the inlet valve circuit on these models?
    Thanks,
    Arthur
    ps I will be checking for an O/C pump
    #135606
    Re: Hotpoint washer/drye, pump blocked cleared now will not
    Certainly does Arthur – breaks neutral circuit around machine, therefore no fill. Check connector block for wire breakage as well as o/c pump.
    Power oiff please……..
    Ok, the wires go through a 90 degree bend up against the the machine side (foam pad) here.
    Cheers,
    Arthur
    #135608
    Arthur121 wrote:Problem as stated above,
    It depends very much on the one vital piece of information missing from your post…..a model number. 😉
    Some Hotpoint Washer dryers will fill with an OC pump, strangely enough, they will not cold fill with an OC dryer thermostat on certain models.
