Re: hotpoint washer dryer 9926
pauly wrote:there is a fan motor that has a capacitor on it how do you test the capacitor
You can’t easily test it but if you suspect it has failed then get a replacement from Maplins or RS as it is not available as a replacement from Hotpoint. 🙁
On the other I wonder why you wish to test it anyway? They never fail in my experience. :rolls:
The fan motor can seize up due to bearing failure or fluff build-up but even then only rarely does that happen! The more usual reason a fan motor doesn’t work is that the 2 wires to it break due to vibration. 😉
