hotpoint washer dryer mod wd62
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries hotpoint washer dryer mod wd62
  • #37523
    Ashby
    hi, having problems with thermal cut out keep going open circuit on the heater box.
    The dryer fan is ok and taken thehousing apart and cleaned out. anyone else had this problem?
    Thanks for your help.
    Ashby
    #255421
    helo_75
    yep
    obviously, check the fan motor (a) isnt loose on the condenser, and catching on the tub when its runnin or (b) the wires to the motor itself tend to breakaround where theyre cable tied to the heater box
    of course, theres always the cold valve to the condenser, thats the usual one tbh
    #255422
    Re: hotpoint washer dryer mod wd62
    Also check the wiring harness where it is lashed to the motor if it has an FHP motor. The plate on the front of the motor often slices through the wiring there. Bend the edge of the plate back with pliers.
    viking433
    of course it could be the customer overloading and dryer overheating???
    #255424
    Tony_EMW
    Could also be switches burning inside timer, very common on this unit producing voltage surges. Try another timer and wait 3 weeks before returning ex unit so you are sure it has solved the problem.
    #255425
    evo1
    yeah, check heater and fan wires on right hand side where clipped to cabinet as well, orange wire chaffed to cabinet, will cause problem………..
    #255426
    Tony_EMW wrote:Could also be switches burning inside timer, very common on this unit producing voltage surges. Try another timer and wait 3 weeks before returning ex unit so you are sure it has solved the problem.
    Are we talking dryer timer or main hybrid timer Tony? I can honestly say that I have never, ever had to change either timer to cure this fault. 😕
    Ashby
    Hi, Thankyou all for your help on this one.
    The only thing i found was an orange wire tied to the motor block had chaffed. everything else is fine. The customers husband did say his wife maybe overloading the machine. He said he will mention it to her, when the time is right.( Rather him than me)
    Much appreciated.
    Ashby 😆
    #255428
    TBH, after customer misuse that is by far the most common cause of TOC’s constantly tripping that I see.
    Tony_EMW
    Jim, I am talking about the hybrid unit. The dryer power circuit switches inside the timer burn more than any others.
    #255430
    Thanks for that Tony, never seen it myself but worth considering if all else checks out. 8)
    Ashby
    Hi, Thankyou all for your help. Unfortunately the thermal fuse has gone o/c again. within 30 mins of switching the dryer on with only a couple of towels in the drum?
    Thanks.
    Ashby
