Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › Hotpoint washer-dryer on/off switch
- This topic has 5 replies, 2 voices, and was last updated 19 years, 6 months ago by
raga.
October 10, 2006 at 1:35 pm #21564
raga
ParticipantHi
I am a complete amateur and need help to fix the on/off switch of my Hotpoint washer/dryer which has almost collapsed inside the control board on the front of the machine.
I just need to know how to open/remove the front control board (the one with all the dials and switches on)?
Many thanks!!!October 10, 2006 at 1:38 pm #191342Martin
ParticipantRe: Hotpoint washer-dryer on/off switch
Model number of the machine please raga?
October 10, 2006 at 1:51 pm #191343raga
Model is Hotpoint WD440P. Thanks
October 10, 2006 at 1:59 pm #191344Martin
raga wrote:Model is Hotpoint WD440P. Thanks
Oh dear! That’s still covered by a 5 year parts warranty by the way. (Hotpoint would need to be called to sort that though) 😕
The switch you describe is all part of the main control PCB (part No 1604899 – about £80 !!) Has the machine been mistreated or damaged in transit for that to have happened I wonder?
Access is after removing the top panel and the dispenser drawer by the way.
:zap: POWER OFF BEFORE INVESTIGATING :zap:
October 10, 2006 at 2:07 pm #191345raga
No I think damage was just due to usage, I pressed the button and it just went inwards and then almost fell in the gap behind the control board. Called Hotpoint but they will not be around for another 10 days and I would like to sort the problem myself or at least try…
How do I remove the top panel and access the switch?October 10, 2006 at 2:27 pm #191346Martin
raga wrote:How do I remove the top panel and access the switch?
Top panel or lid : remove 2 screws at the back, gentle raise the panel at the rear very slightly whilst giving a sharp tap (with the palm of your hand) to the front of the lid to release it from the lugs that hold it against the front control console.
I’m fairly sure you will need a complete new control panel as mentioned before though. Tampering with the machine may well invalidate the guarantee don’t forget!
Softly! Softly!
