Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Hotpoint washer dryer WD420P
- This topic has 5 replies, 4 voices, and was last updated 15 years, 7 months ago by
sce.
September 9, 2010 at 6:56 pm #57143
sce
ParticipantHello….yet again!I have a problem with a Hotpoint WD 420P washer dryer.Serial no 53220129.Problems are as follows and only concerns the use of the dryer,apparently the wash/spin part is ok.Problem 1-if set on 30 mins worth of drying it switches off atfer 55 mins-is this normal?problem 2-sometimes,though i never got it to do it, they get 2 lights flashing and these are rinse hold and time saver which are the 3rd and 4th lights of the bank of 5 optional lights=ntc fault apparently ,which is somewhat odd.Prior to this the machine had a new wash element and so i double checked the 2 wires plug which is ok(must be otherwise m/ch would go wrong on the wash cycle and it doesn`t).The dyer element heats up ,the dryer ntc stat is ok,the fan works,the dryer valve works,and the stupid o/load stat is ok.Anybody got any ideas please,thanks.
September 9, 2010 at 7:03 pm #330002keithwilliams
ParticipantRe: Hotpoint washer dryer WD420P
i’ve had machines of various hotpoint models particularly wf giving ntc faults and some doing weird things. in each case a brand new ntc has not cured the problem. however i’ve referred them to hotpoint who’ve fitted new modules to fix it.
hope this helpsSeptember 9, 2010 at 9:23 pm #330003sce
Thanks for your reply.I agree with you that it is probably the pcb though i was hoping ,of course ,it wouldnt be,c`est la vie.Anyone elses imput more than welcome before i break the dreaded news to my customer next week.Thanks in anticipation.
September 9, 2010 at 9:31 pm #330004leavemetogetonwithit
Have you tried a search? I recall seeing masses of threads on these.
Mike.September 10, 2010 at 6:38 am #330005allan73
Ring EMW……
September 28, 2010 at 6:34 pm #330006sce
sussed it-nothing to do with the lights as quoted flashing as she told me the wrong lights-i give up!!!!Asked her if the dryer actuallly dried anything and she said it didn`t-shame she didn`t telll me before!Actual problem was the dryer vave solenoid o/circ;simple as that.Problem now solved ,thanks for everyones suggestions.
