Hotpoint Washer Dryer WDM73
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Hotpoint Washer Dryer WDM73
  • #69748
    usermatt1415
    hi can anyone help as my washer keeps leaving black marks on the whites after the full wash cycle. it did the same on my previous washer indeset (spare) so i swapped it to the hotpoint and it still does it . any ideas thanks matt
    #375840
    Re: Hotpoint Washer Dryer WDM73
    It’s not the machines, it’s the user. Constant low temp washes, especially with liquids will cause this.
    #375841
    usermatt1415
    hi if i do a hot wash with nothing in will that sort it? also the drum semms to be catching on something when i spin it manually? the weights had come loose at the bottom so i tightened them up but it still catching in a certain pllace thanks matt
    #375842
    Ohhh dear, not sounding good….drum bearing failure I expect, drum shaft loose? Noisy on spin too is it?
    #375843
    Sounds like the alloy drum support may have broken, this will cause black marks and is a common failure when using liquids and mostly low temp washes.
    #375844
    usermatt1415
    hi thks for replies it is now tripping the electric as soon as turn it on thks matt
    #375845
    Sounds like the inner drum has damaged the heater.
    #375846
    usermatt1415
    thks for reply. i have put the indeset washer back in ,did a 90 degree wash with nothing in then a darks wash at 40 then a whites wash at 40 and all the whites have black marks on them . dont know what to do any ideas? thks matt
    #375847
    usermatt1415 wrote: i have put the indeset washer back in ,
    Hold up!….I thought we were talking about a Hotpoint?….now you have an Indesit doing the same…..is that the story?
    #375848
    usermatt1415
    sorry the hotpoint started with black marks then drum was catching on something then kept tripping electric . i have a indesit so put it in but keeps leaving black marks on whites thks matt
    #375849
    TO be fair Martin, usermatt1415 does mention his duff Indesit in his first post. 😉
    #375850
    iadom wrote:TO be fair Martin, usermatt1415 does mention his duff Indesit in his first post. 😉
    Sorry but I missed that bit……Clearly this guy Matt has got not one but two heaps of junk in his kitchen then…shall you tell him or I…?
    #375851
    usermatt1415
    is there nothing i can do then ? thks matt
    #375852
    To be certain of the extent of the problem the WDM needs to be fully stripped down to determine the extent of the damage. Is that within your capabilities?
