Hotpoint washer dryer WDPG 8640 -F05 error
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Hotpoint washer dryer WDPG 8640 -F05 error
  • #86630
    twicknix
    What is F05 error? One says pressure switch stuck unless I’m looking up on wrong error code?
    Clothes came out steaming hot and damp. I cleaned out condenser and dryer unit. It drains ok. What have I missed out?
    Cheers
    Matt
    #432412
    Re: Hotpoint washer dryer WDPG 8640 -F05 error
    99{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} of the time F05 is a blocked pump. Clothes steaming and hot is usually due to a failed condenser water inlet valve.
    #432413
    twicknix
    The customer says that it washes well only when it comes to tumble dry that the clothes comes out damp and hot. With the outcome it showed the F05. I am guessing that the inlet valve is the problem even though it is not relating to the drain pump?
    #432414
    Guessing is sometimes the only option. :rolls:
    #432415
    johnnyj
    I would have a pop at the dryer thermistor prone to giving F05 faults
