Re: Hotpoint Washer Motor
the original GEC motor is no longer available. you would have to fit the later motor and a fitting kit that means a wiring mod. got the mod you need an IDC (insulation displacement connector) tool to connect the wires
motor C00118057
fixing kit 1 C00202905
fix kit 2 C00202906
you will prob need fixing kit 1
but beware the wiring is not 1 for 1 the connections are not in the same order as the original so you would have to work out where they go by measuring the old motor to the new one
think i may have the instruction somewhere but i may have to go digging
