Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › hotpoint washer water making way back in
- This topic has 10 replies, 3 voices, and was last updated 18 years, 10 months ago by
Webby69.
July 5, 2007 at 1:50 pm #28751
Webby69
ParticipantHi, our hotpoint aquarius wf250 washing machine has started to let water back into the drum after a wash cycle.
Everything else works ok wash, spin etc.But when its been standing for 24hrs or so when we open the door there is a collection of water in the bottom of the drum.
Any ideas why.Thanks
July 5, 2007 at 1:52 pm #219891kwatt
KeymasterJuly 5, 2007 at 1:55 pm #219892Webby69
ParticipantRe: hotpoint washer water making way back in
Thanks for that quick response, will check up on that later tonight.
Many thanks
July 5, 2007 at 3:54 pm #219893iadom
ModeratorRe: hotpoint washer water making way back in
Worth mentioning that this machine should have a non return valve in the pump which should prevent water seeping back in from the outlet.
If the water is clean then you may have a faulty inlet valve, very rare on such a young machine but not unheard of. If it still leaks in after you have eliminated the outlet/drain pipe as a possible cause then if the machine is hot & cold fill, turn off the tap to either hot or cold. If it doesn’t fill overnight then the valve from the supply you have turned off is faulty, if it still fills then obviously the other one is.
If it is a cold fill only then turn off the cold tap overnight.
July 17, 2007 at 8:55 am #219894Webby69
iadom wrote:Worth mentioning that this machine should have a non return valve in the pump which should prevent water seeping back in from the outlet.
Thanks for that jim will have ago at this tonight as before i went on our hols i checked the waste pipe etc and it was clean no sign of blockage etc and yes the water is clean.
Ill turn one of the feeds off later to try and find which one it is.
Presuming the out come will be that what will i be looking at etc for fixing itThanks
July 17, 2007 at 9:40 am #219895iadom
Inlet valves are not expensive or that difficult to change.
July 21, 2007 at 12:15 pm #219896Webby69
Narrowed the culprit down its the cold water valve thats letting water back into the washer.
Thanks for all your help just need to get the part sorted now.July 21, 2007 at 12:33 pm #219897iadom
July 21, 2007 at 12:53 pm #219898Webby69
How do i know which one i need?
:rolls:
Its the wf250 1500spin aquarius model if that helps.Thanks
July 21, 2007 at 1:00 pm #219899iadom
None of those in that case, you need a 1604490, an e-mail to spares@ukwhitegoods.co.uk should do the trick. It will be a little dearer than those but not over expensive.
July 22, 2007 at 9:24 am #219900Webby69
Thanks again 😀
