Hotpoint washer WT540
  • #45791
    johnnyhoz
    Hi All
    went to this mahine today, as soon as you put power on lights flash rapidly, the verticle row 1,2,3,and 4 are flashing and on the horizontal lights number 5 together with the on/off lamp.
    The cause of the fault was a bath mat which broke up blocking the filter.
    seems strange that this has caused the board to fail but can’t see anything else obvious, any advice would be greatfully accepted
    John
    #287082
    Re: Hotpoint washer WT540
    It doesn’t need anything to cause these boards to fail, all lights flashing is quite common. if unplugging for five minutes doesn’t clear it then send it of to EMW for test/repair.
    johnnyhoz
    Thanks Jim Will do
    John
