hi guys what is the best way to clear a blockage on these machines, with the pressure switch .that knackers the board if tip the machine back ?what models are they /or how do you identify them . does the pressure switch look a certain type ? help please :rolleyes:
I came across 2 machines that wouldn’t start a wash after they were both blocked and cleared. I threw some water into the drum and set it to a spin. It will eventually go into a spin. Let it finish. In both my cases it reset the machine and worked ok. Maybe i was lucky.
