Hotpoint washing, and washing, and washing….
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Hotpoint washing, and washing, and washing….
  • #49881
    PaulGreyhead
    I have a Hotpoint WD420 washer dryer. I’ve just replaced the main PCB and the front control PCB (both refurbished).
    There are no flashing lights and everything works fine when using the individual settings, but when put on a wash, it just keeps washing! It doesn’t stop and rinse, just keeps washing.
    Can anyone shed light on this problem please? Is there some way I can reset the machine?
    (I’m just polishing my sledge hammer in case I need to use it! 😆 )
    Thank you.
    #302613
    Washman
    Re: Hotpoint washing, and washing, and washing….
    Has the module been programmed for this machine.
    Mike
    #302614
    helo_75
    HEATER WIRES / HEATER?
    unless, as mike says, its not programmed right
    #302615
    PaulGreyhead
    Thanks for the replies.
    Yes it’s programmed for this machine (as far as I know!). It was double checked too as I sent it back for the company to confirm it was working.
    The heater and wires were ok when I put it back together and tested them. I’m planning on checking it out again to see if there is anything obvious happening.
    I was hoping there was a simple reset sequence I could try but I can’t find anything on it.
    #302616
    gandh1
    out of interest… how long is “stuck in a wash cycle” long?
    #302617
    PaulGreyhead
    Just short of three hours!
    #302618
    gandh1 wrote:out of interest… how long is “stuck in a wash cycle” long?
    Will wash indefinitely with O/C heater. 😉
    #302619
    PaulGreyhead
    Tested the heater and it is indeed dead! Ordered one from here so hopefully that will cure the problem.
    Many thanks once again guys for the help and advice.
    #302620
    PaulGreyhead
    Just thought I’d give an update.
    I replaced the main heater element as advised and the machine now seems to be working properly.
    So thanks again to all that helped me with this.
    I did however notice something that I think is wrong, and I’ve made a new post here: http://www.ukwhitegoods.co.uk/modules.p … 298#250298
    Any help with the new problem (if it is a problem!) will be greatly appreciated.
    Many thanks.
    Paul
