Hotpoint Washing Machine Bearings
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Hotpoint Washing Machine Bearings
  • #66518
    kickass47
    Before I strip my machine down, does anyone know if the sticker on the back of my Hotpoint Aquarious Washing Machine gives shaft size details to change bearing set
    The sticker says:- 0035 WMA46N 15143606
    Also would it be recommended to change the spider at the same time
    Regards
    Chris
    #364414
    Re: Hotpoint Washing Machine Bearings
    TBH you would be far better off stripping the machine down first before you order anything.
    Then you can find out which bearings it has, if they will actually come out of the drum and also see if the drum shaft is damaged.
    #364415
    washtronics
    the 0035 should state that the bearings are the 35mm type and not the 30mm type
