if you post the model number and clarify wether its just the door locked light flashing or any another other lights someone will help you.
if its just the door lock light try opening the door and closing it again.
if you go any further plug out please.
suedehead1 wrote:if you post the model number and clarify wether its just the door locked light flashing or any another other lights someone will help you.
model number is wma 32 and it is just the door light that flashes then goes off and the washing machine does not still work
1st step.
Does the door shut properly?
Does it lock when shut?
Can you easily open the door without much pressure on the door latch?
These faults are usually due to one side of the door latch spring having been snapped off so you think you are shutting the door but there is no pressure to push the latch to activate the door interlock.
