Hotpoint Washing Machine Mod. WF740
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Hotpoint Washing Machine Mod. WF740
  • #26617
    Ashby
    Hi, Can someone tell me please what fault code F12 is? Customer says that code is being displayed. I have no imformation on this model.
    Many Thanks.
    Ashby 😕
    #210831
    Re: Hotpoint Washing Machine Mod. WF740
    All this information is in the Known Error codes thread, a combination of the WF flahing codes and the Indesit WIDL codes gives you F12 as communications error, may be poor connections but just as likely to be faulty main PCB.
    helo_75
    or u could just unplug it… leave it for 10 mins, and plug it in… it sometimes works
    #210833
    Ashby
    Hi, Does someone have a wiring diagram for the main PCB please? The customer thought he was being helpful by removing the pcb before i arrived. Unfortunatly he didn’t make a note of the connections.
    Many thanks.
    Ashby 😥
    #210834
    Check your mail. 😉
    Ashby
    Thanks Jim. Much appreciated.
    Ashby
    #210836
    Ashby
    Hi, Just had main PCB back from EMW. Put it back on machine, set programm to drain as soon as i pressed the start button it blew again. Before i sent the board away, the machine was just filling continuously.Unable to cancel or reset program. Any ideas what caused the board to blow in the first place? I’m worried about fitting another board untill i know what caused the problem.
    Thanks for your help.
    Ashby
    #210837
    Lawrence
    Don’t these have a history of door lock’s blowing boards ?
    Lawrence
    #210838
    Ashby
    Hi Lawrence, Thanks for your help, i have heard about the interlocks on these machines. just wanted to know if there may have been anything else that could have caused the board to blow. The machine is only just over 12 months old. I’ll change the interlock and check all other parts before i change it again. Thanks.
    Ashby
