Hotpoint Washing Machine Mod. WF740
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Hotpoint Washing Machine Mod. WF740
  • #29424
    Ashby
    Hi, This machine is coming up with fault code H20.
    I’ve changed the solenoid valve as that was faulty. The machine will start to fill and only take in a small amount of water. Then after a few moments the error code comes up. If i cancel the program and start it again a couple of times it will fill to the correct level and carry on until it comes to rinse.then it wont fill again. Has anyone elese had this problem?
    Thanks for your help.
    Ashby
    #223057
    Ashby
    Re: Hotpoint Washing Machine Mod. WF740
    Hi Again,. Has anyone any idea what is going on with this machine please? Thanks.
    Ashby
    #223058
    I have not come across this fault. not sure if any of the Hotpoint lads have. It could be a faulty main board or loose connections to the board although trying a pressure switch would be a cheaper alternative I rarely change pressure switches on these.
    HotDog
    Check pump/filter for blockage can cause back pressure if ok board faulty they nearly always are 😆
