Hi guys, easy question for somebody in the know, but I need a motor for a hotpoint washer, model wml560 p uk.r – 011085437 – 30646210001.
Connect are listing about 4 variations but I can’t identify which one. Mine has 7 contacts on the motor block if this helps.
Many thanks as usual guys
C00280608 there is a problem with the files loaded onto the module with some of them which causes the motor brushes to arc and burn out the motor, it requires reprograming the module to cure.
Cheers for that Johnny, i’ve heard something similar today from a Hotpoint engineer. He says he tells his customers after a motor change to try and avoid the 1400 spin and keep to 1200 at the most, didnt mention re programming it, but thats probably just him.
Thanks again pal.
