Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › Hotpoint washing machine not filling
- This topic has 9 replies, 4 voices, and was last updated 9 years ago by
Liz48.
March 12, 2017 at 10:49 am #90794
Liz48
ParticipantHotpoint WMFUG942 13 months old – will not fill with water. Error code F05
It will take a very small amount of water in part of the rinse cycle.
Have checked the filter, removed the drainage pump and hose from drum to pump – pretty gunged up but now clean. Have checked the outlet pipe. Put 2 gallons water into drum and selected pump – all the water cleared easily.
Have replaced the cold water fill solenoid with genuine Hotpoint part. Still the same problem.
Have remove tube at base of pressure sensor – NO audible click heard. Have blown through tube and it was clear. I have gently blown and sucked the base of the pressure sensor and can feel movement, but no audible click.
Tried to locate the pressure chamber – could not find one.Any ideas? Do I need to replace the pressure sensor?
March 12, 2017 at 11:20 am #446010iadom
ModeratorRe: Hotpoint washing machine not filling
No click in a digital pressure switch, blowing into it can damage it though.
Given what you have already tried then a new pressure switch would be the next option.
I know it might seem obvious but you have checked that have water coming out of the inlet hose?
PS, there is no accessible pressure chamber on these sealed drum machines. 🙁March 12, 2017 at 11:33 am #446011Liz48
ParticipantRe: Hotpoint washing machine not filling
Thankyou for your prompt reply.
Yes, there is a good mains water supply coming out of the inlet hose and the hose is not kinked.
I will get a new pressure switch and try that.
Thankyou.March 16, 2017 at 4:35 pm #446012Liz48
Have changed the Pressure Sensor – problem fixed – Thankyou.
March 16, 2017 at 5:16 pm #446013iadom
Thanks for updating us.
May 27, 2017 at 2:32 pm #446014SPMidlands
I have the same machine and same issue with F05. as Liz48
In fact my machine (17 months old) was working perfectly when i decided for the first time to check open the round thingy at the bottom, a few shirt collar plastic bits came out and a small amount of water, closed it all up and then started the machine a few days later (yesterday) and almost nothing apart from water extraction at start and then sits like a lump of metal with a timer.
I’ve pretty much done exactly what Liz48 did even in the same order including blowing into the blue pressure switch (code 16002692101 – product code C00289362) which I understand you should not do (point taken about no clicking sound on this one)
Machine seems to spins fine and continues to cycle to the end where no water is required (10 / 37 minute cycle I think), the only issue is that it sometimes takes ages for a small amount of water to come into the machine, the drum rolls a few times, and then the water is pumped straight out, and a short time later, the F05 error pops up.
No hose issues as i blew through all the pipes and used the waste pipe directly into the sink to see if any blockage existed, so that wasn’t the problem
I’m guessing I should invest in a replacement water pressure switch and hopefully this may cure it? being a BH i’m not going to get one until at least Wed/Thu next week.
For info I called Hotpoint first, said I could pay £120 with 90 day warranty or £15.99 over 12 months (£190.80) with 12 mths warranty, for engineer visit, politely declined, especially as you can buy a new one for £250 from Currys and pick it up straight away.
If the advice is get the switchh, I’ll feedback once I’ve replaced it to see if this cures the problem.
Thx for any feedback
SPMidlands
May 27, 2017 at 3:05 pm #446015Seamy
Don’t blow into pressure sensor, it damages them and deffo won’t work after this.
May 27, 2017 at 4:07 pm #446016SPMidlands
Good advice, thanks, will definitely not do this with the replacement once its arrived.
just for interest, pre and post blowing made no change to the results as I tried all sorts of things and wash cycles to see what would happen.
fingers crossed.
June 1, 2017 at 8:20 am #446017SPMidlands
Hi Everyone,
Pressure Sensor, arrived yesterday afternoon whilst I was at work, took about 2 minutes to pull the machine out, open the lid and carefully replace it.
Placed the plug back into the socket, switched it on, and hey presto it whirred back into life. Sooo pleased that I saved £100/£170 by not getting Hotpoint to send the engineers round.
It’s now time to send a formal complaint to Hotpoint to request why their machines fall apart after a year and a bit and ask them for a refund of my costs to fix their shoddy workmanship.
Stay tuned, for developments.
June 1, 2017 at 9:44 am #446018iadom
Don’t forget to mention that in all likelihood you damaged the pressure switch yourself by blowing into it. Also mention that you allowed foreign objects to block the pump in the first place. 😉
