Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › Hotpoint washing machine – Size of problem
- This topic has 13 replies, 5 voices, and was last updated 21 years, 8 months ago by
admin.
August 4, 2004 at 7:05 pm #5968
KeymasterSlightly daft enquiry but i have the chance of a free Hotpoint washing machine WF840, but i am a bit short of space.
Its quoted as having a depth of 580mm. Does this measurement include the pipes, electrics and drum which sticks out of the back of the unit?Many thanks
August 4, 2004 at 7:09 pm #114843admin
KeymasterRe: Hotpoint washing machine – Size of problem
the size given is that of the actual appliance,you must therefore give yourself normally at least 1 1/2″ behind the appliance for the waste pipe ect.
bryan
August 9, 2004 at 11:35 am #114844admin
❓ I have just bought one of these (Hotpoint WF840) and after installing it, it seems to use no hot water. Checked all the obvious… yes we have hot water, its turned on, and it comes out of the machine end of the hose. Is this normal for this model?? Nothing was said at sale time about it being cold fill and in the instruction manual it talks about the “hot water temp must not be over 60 degrees”, “If you want to use it cold fill only you must buy an adapter” … etc.
Any advice greatfully received.
Thanks.August 9, 2004 at 11:52 am #114845Dave_Conway
ParticipantRe: Hotpoint washing machine – Size of problem
You’ll almost certainly find that the machine only takes hot water from your system on washes 60C and above, maybe even the 60C only takes cold water.
Due to the low energy rating of these machines, it is far more efficient for the machine to heat and regulate the temperature itself, and yes, it’s quite normal. nearly all modern machines are the same.
Unless you have a supply of “free” hot water, it should be more cost effective letting the machine heat the water it uses.
August 9, 2004 at 11:59 am #114846Martin
Your Hotpoint WF840 does indeed take in hot water as and when it is required, usually only on the high temperature programmes though. Most 40degree washers these days will fill with 90{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} cold 10{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} hot (approx).
August 9, 2004 at 12:22 pm #114847admin
😈 We have even tried a 95 degree wash (“clean cycle”) and it still only took in cold. It did heat up to 95 mind you, as the door glass was too hot to touch.
I contacted Hotpoint who told me that it was realy cold fill but may use enough hot water to rinse out the soap tray on the wash part of the cycle. This doesn’t seem right to me as I have a hot water tank upstairs that has been heated by a very efficient gas boiler and I am having to heat up cold water by electricity as well!?! I thought the energy efficiency meant that it would use whatever it could get, hot water wise, and just tweak it as little as possible.
Am I expecting too much from this then??
Also the instalation instructions don’t say anywhere that we don’t need a hot supply and that we should make sure that the pipes are connected the right way round. A lady on the Hotpoint servicedesk suggested we swap over the pipes to see if it would then use the hot water!!! Hmm lovely hot washing at the end of the cycle …. I don’t think so!!!!So I suppose what I am ultimately asking is … is this a faulty machine or is it working as designed??
Thanks for your swift responses on this.
August 9, 2004 at 12:50 pm #114848Dave_Conway
Guest wrote:So I suppose what I am ultimately asking is … is this a faulty machine or is it working as designed??
The latter in my opinion, although without seeing it, it’s impossible to be 100{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} on this.
August 9, 2004 at 2:32 pm #114849Martin
Guest wrote:I contacted Hotpoint who told me that it was realy cold fill but may use enough hot water to rinse out the soap tray on the wash part of the cycle
What a lot of rubbish, and from Hotpoint too 😕
On a 95 degree cycle, the moment you press the ‘Start’ button, the machine will ‘pump’ for 5 seconds, (to clear the sump ball valve actually) It will then fill with ‘Cold’ water for approximately 15 seconds, THEN it should fill with HOT and continue until it has reached its preset water level (determined by the wash load you have selected)…The only exception to that being that if the incoming hot water IS TOO HOT, then it will fill with cold, until the temperature sensor has cooled down at least (*)
I recommend calling out one of their ‘engineers’ to check it out at least 😉
(*) I suspect a faulty thermistor sensor (IMHO)
Please advise us of the outcome…thanks 🙂
January 12, 2005 at 10:20 pm #114850admin
Keymaster‘test’ instead of program requested
My wf840 is going into ‘test’ everytime I try to use a program. How do I cancel this and just get on with using the machine? It is only 6 months old but I am unable to find the manual after searching for it.
January 13, 2005 at 12:15 am #114851Dave_Conway
I’m not familiar with this particular model, try holding the “start” button in for a few seconds 😉
January 14, 2005 at 3:11 pm #114852DAZ123
if you accidently hold the start and on/off buttons it puts it into a test/demo mode. you need to push start and on/off again and “doff” should appear, you should now be able to use the appliance as normal. Abit bit of naff idea having the buttons that enter the test mode so close togehter if you ask me 🙄
August 24, 2005 at 6:55 pm #114853admin
would anyone happen to have a manual on the pc for this washing machine
thanks
August 25, 2005 at 6:59 pm #114854admin
Sorry folks but the WF840 and all the later machines primarily fill with cold once they are filled if they req more water due to clthes soaking up water and a need to top up they will top up with hot then, but lately they have reverted to cold fill only resulting in no hot valve.
August 25, 2005 at 11:40 pm #114855Penguin45
Hello Guest,
Thanks for your input. As you obviously have technical knowledge, please do us the courtesy of becoming a member. It is worth it.Regards,
Penguin45. -
