Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Hotpoint washing machine WF000
- This topic has 9 replies, 5 voices, and was last updated 16 years, 11 months ago by
megawatt.
April 26, 2009 at 8:22 pm #45245
megawatt
ParticipantCalled out to dead machine. Checked power out of filter to be good, assumed power board to be duff and sent it off to EMW. To my suprise it came back as no fault found. I think the next step will be the top board. Have any of you guys come across a fault the same as this and what caused the problem?
Mike.April 26, 2009 at 8:51 pm #285004iadom
ModeratorRe: Hotpoint washing machine WF000
Had several, always been the power board. ❓ ❓
April 26, 2009 at 10:48 pm #285005helo_75
ParticipantRe: Hotpoint washing machine WF000
iadom wrote:Had several, always been the power board. ❓ ❓
only he said emw checked it
anyway, the two buttons on the bezel will be sticking
check machine function with front pcb off machineApril 27, 2009 at 9:10 am #285006iadom
helo_75 wrote:
iadom wrote:
Had several, always been the power board. ❓ ❓only he said emw checked it
Thats why I added the befuddled question marks Rob. 😉
April 27, 2009 at 11:36 am #285007Phidom
Or interlock? You usually know if that’s the problem as the door locked light flashes but the other day my own Hotpoint was doing odd things. At the end of the wash the door was hard to open and the locked light came on for a couple of seconds after I opened the door :rolls:
April 27, 2009 at 5:49 pm #285008megawatt
I see your point, but this is just like it is switched off at the mains. I am off to it tomorrow and I will let you know. Odds on favourite is the top board switch.
April 27, 2009 at 7:38 pm #285009maltheviking
Check tactile switches on console PCB for dry joints, you will need a magnifying glass if you eyes are owt like mine
April 28, 2009 at 3:10 pm #285010megawatt
Went back today armed with every possible part I could think of. Refitted board and all worked ok. Looks like it was an intermittent board or bad connection.
Thanks for your comments,
Mike.April 28, 2009 at 3:22 pm #285011maltheviking
maltheviking wrote:Check tactile switches on console PCB for dry joints, you will need a magnifying glass if you eyes are owt like mine
As I said 😉
April 28, 2009 at 4:09 pm #285012helo_75
Participanterm, it was the buttons sticking if you want to be factual
ive done hundreds
