hotpoint wd 420 spinning on dry cycle
Home Forums Public Support Forums Help And Support Washing Machine Help Forum hotpoint wd 420 spinning on dry cycle
  • #77836
    mark-t
    i have a wd420 problem no flashing lights but goes into spin after about 15 minutes of drying cycle everything else is fine ???
    #403565
    Muv
    Re: hotpoint wd 420 spinning on dry cycle
    Thats normal for these machines,its called a thermal spin..as long as it stops and carrys on drying normally…its not a fault.
    Sent from my iPhone using Tapatalk – now Free
    #403566
    Thermal Spin
    A thermal spin on the High Heat setting is carried out at the start of the of the drying process. The load is pre-heated to approximately 50°C by the dryer heater with normal tumble action and pump out.
    The thermistor located in the wash heater will sense the load temperature and when 50°C is achieved a 5 minute Spin profile will be carried out at full spin speed.
    During thermal spin the Out of Balance detection will operate and maximum speed will only be achieved depending on the out of balance condition.
    On completion of the Thermal Spin, the tumble drying process will commence for the period of time selected.
    Thermal spin is NOT available when low heat is selected.
    #403567
    mark-t
    Brilliant thanks for the help guys
    #403568
    Can this thread be moved to correct forum as the info within may well be useful to others?
    #403569
    Sorry Martin, was in a bit of a rush this morning and missed that. :clown:
    Moved to correct forum. 😆
    #403570
    iadom wrote:Sorry Martin, was in a bit of a rush this morning and missed that. :clown:
    Off to OT now to pluck them Canaries. :mrgreen:
    #403571
    Andy jones
    Anyone know what the point of this spin is ??
