Hotpoint WD 645 Various errors
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Hotpoint WD 645 Various errors
  • #79480
    big3card
    Hi all, just got a WD 645 that’s giving various errors.. f04, then f07 then it gave f11… with the washer continuously emptying .
    I’ve found all parts referring to the error codes to be ok and also checked the pipe from the sump to the pressure switch all to be ok so am at a loose end and looking for a little help …b3
    #409405
    Re: Hotpoint WD 645 Various errors
    When you say ‘just got’ do you mean you have just acquired this machine?
    Not sure how you managed to check the F07 (heater relay) fault but it sounds like the main pcb is faulty or it may be damp due to water ingress from the dryer assembly above it.
    F04 can also be a pcb fault, F11 is supposed to signify a none activated drain pump.
    #409406
    big3card
    Sorry for the late reply .. I got it from my sister as she had a upgrade
    I had a suggestion about the heater being faulty or the stat ? but cant see it myself thought id ask?
    #409407
    The heater itself can be easily tested with a suitable multimeter or better still a megger.
    There are no thermostats in this machine.
    All those various error codes flashing up suggest a pcb fault or bad connections due to a ‘robust’ transit.
    #409408
    big3card
    I’ve checked the main board and cant see no ingress and looks in quite reasonable condition with no burnt or damaged tracks either… I also put my meter across the heater with a reading of 0.025 ohms is this correct? Regards .
    #409409
    Andy jones
    Are you sure that it’s not 25 ohms ??
    #409410
    Wash heater should be around 30?. Dryer heater approx. 43?.
    Just looking at the main pcb is not enough to tell if it is OK or not, that said as it has Indesit electronics in it then just looking at the pcb on these is enough to cause them to fail.
    You need to test all components, especially both heaters and motor for insulation readings. Also the dryer ntc can give several spurious error messages.
    #409411
    big3card
    yes sorry its washer heater 30.9 and the dryer heater is at 44 ill next go for the ntc on the dryer as this was the problem on my aqualtis but that only threw one error. regards
    #409412
    Important to do an insulation test not just resistance and continuity. 😉
    #409413
    big3card
    just getting the f11 error now, with it emptying … f11 is a none activated drain pump but this one is on (activated) so wouldn’t this point to a dodgy pressure switch or am I just chasing my own tail!
    #409414
    big3card
    also completes a spin cycle just to add ?
