Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Hotpoint WD420
- This topic has 9 replies, 3 voices, and was last updated 18 years, 2 months ago by
DDDave.
January 28, 2008 at 4:41 pm #34132
DDDave
ParticipantHi Guys, Its my first time posting here after browsing for months.
I cant find this fault listed in the fault code section. On the above machine there is a vertical row of lights and switchs on the lhs. From the top lights 3 and 4 come on seconds after starting the machine. Any advice would be appreciated.
DaveJanuary 28, 2008 at 4:51 pm #241396loopey
ParticipantRe: Hotpoint WD420
wash thermister open/short circuit , check connections and thermister ..
January 28, 2008 at 4:57 pm #241397DDDave
loopey wrote:wash thermister open/short circuit , check connections and thermister ..
Thank you loopey.
I will give it a try.
DaveJanuary 28, 2008 at 6:27 pm #241398iadom
ModeratorRe: Hotpoint WD420
DDDave wrote:
I cant find this fault listed in the fault code section.They are there, page four of the Known Error Codes thread. 🙂
January 28, 2008 at 8:14 pm #241399DDDave
Hi Jim.
That gives me fault code O3 – F03….OFF, OFF, Flash, Flash, OFF.
Can you tell me where the list is to decode the fault code.
DaveJanuary 28, 2008 at 8:36 pm #241400iadom
It tells you at the top of that post.
These can be read in conjunction with Dave Conway’s post on page 3 of this thread regarding WIDL codes.
January 28, 2008 at 9:42 pm #241401DDDave
iadom wrote:It tells you at the top of that post.
Doh ! Got it.
Thanks again guys
DaveFebruary 5, 2008 at 4:27 pm #241402DDDave
I am still having problems with this machine. I have replaced the element & thermister but the same fault code still comes up. I have also tested the wiring from the board to the thermister , its ok. Is there a reset on the board ?? Any ideas please.
February 5, 2008 at 4:53 pm #241403iadom
No reset, these Indesit boards are very unreliable and are often as not the source of the fault. 😥
February 6, 2008 at 12:17 am #241404DDDave
Ok , thanks Jim.
