Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Hotpoint WD420
- This topic has 14 replies, 6 voices, and was last updated 17 years, 10 months ago by
DDDave.
May 20, 2008 at 10:17 pm #36864
DDDave
ParticipantHi Guys. I am having a problem with a WD420. Initaly the fault code was for NTC fault so I replaced that but that didnt work. I got a new board for it and now it comes up with comunication error. I have cleaned all the connector blocks and tried a new selector panel. Do the new boards need to be programed ?? Any advice please . Thanks.
Edit WD420May 21, 2008 at 6:06 am #252601BobHope
ParticipantRe: Hotpoint WD440
Hi Dave
what is the full model no. or better the 5 digit commercal code,
what eprom have you fitted to the pcb.bob.
May 21, 2008 at 11:25 am #252602kiddo66
Did you change both thermistors as the wash thermistor can play a part in faults with these washers.
May 21, 2008 at 9:49 pm #252603DDDave
BobHope wrote:Hi Dave
Hi Bob.
WD420P 51105183 603105183 are all the numbers on the machine.
The new board numbers are 09021500915503
DaveMay 21, 2008 at 9:51 pm #252604DDDave
kiddo66 wrote:Did you change both thermistors as the wash thermistor can play a part in faults with these washers.
I changed the wash thermister and tested the dryer one. Both tested ok.
May 21, 2008 at 10:11 pm #252605iadom
ModeratorRe: Hotpoint WD420
You didn’t answer Bobs second question, you did fit a new eeprom to the new PCB didn’t you?
May 21, 2008 at 10:32 pm #252606DDDave
ParticipantRe: Hotpoint WD420
iadom wrote:You didn’t answer Bobs second question, you did fit a new eeprom to the new PCB didn’t you?
DOH. No, I thought the board was complete !!May 21, 2008 at 10:46 pm #252607iadom
DDDave wrote:
iadom wrote:
You didn’t answer Bobs second question, you did fit a new eeprom to the new PCB didn’t you?Jim.
DOH. No, I thought the board was complete !!When I saw this post this morning I suspected as much. 🙂
Now your problems really start. At least three different eeproms. Is it hot & cold or cold fill only, has it got a screwed or welded drum, what type is the motor, what is the commercial code, it doesn’t appear to be part of the numbers you gave.
May 22, 2008 at 12:20 pm #252608DDDave
Its a cold fill , screwed drum, UOZ 112G63 motor. There is no code on the machine, I have checked everywhere on it !
May 22, 2008 at 1:27 pm #252609stripey
The comercial code should be on the rating plate it is an eleven digit number. To get the correct EPROM for a WD you need to know what type of heater box is fitted Version 1,2 or 3. I suspect from the SN you supplied that it will be a Ver 3 box. I havent got access to part numbers at the Mo but I am sure someone can help you out.
May 22, 2008 at 2:07 pm #252610iadom
I meant who manufactured the motor.
If it is a CESET motor with a 52cm field coil you need eeprom C00259530.
If it is cold fill with the latest heater box which includes a flushing valve then you need C00203613.
If it is a cold fill with mk 1 or 2 heater box then you need a C00203185.
The commercial code should be 31127, it should form part of the 11 digit number that stripey refers to.
May 22, 2008 at 10:22 pm #252611DDDave
ParticipantThanks all. I will have to recheck it again in the morning.
May 23, 2008 at 8:07 am #252612roly16
Blimey 😯 . And we wonder why youngsters don’t want to do this job these days.
May 23, 2008 at 11:59 am #252613DDDave
😀 Unfortunately I am not a young lad. 24 years in the business but have not had this problem before. I went to my suppliers this morning. They had the correct eprom in stock (why didnt they tell me I needed one when buying the board ?? :violent: ). Parts are fitted and machine has gone through a test wash. 8)
Thank you all for your help.
DaveMay 23, 2008 at 2:53 pm #252614iadom
Thats the power of UKWG’s for you, glad to hear you sorted it. 8)
