Hotpoint WD420
  • #39323
    maltheviking
    Fixed one of these today, leds 1+2 flashing, comms prob. loose plug 🙂
    I put the machine on test and it filled up ok, when the motor started it came on for about 1 second switched off, then did the same in reverse. 45 seconds later it did the same and continued to do this about 10 minutes, then went into normal agitation.
    The owner advised me that it has done this from new
    I suspect the eeprom is corrupt, any other ideas chaps and chapesses or is this the norm for this model? 😕
    #262043
    johnnyj
    Re: Hotpoint WD420
    Reprgramed a few to cure this, jj
    #262044
    maltheviking
    Re: Hotpoint WD420
    Thanks Johnnyj
    It be a new module and eeprom then cos I can’t get the software to re- program 😥
