Re: Hotpoint WD420 doing strange things!
Little update…
Disconnected then tested heater element, which was fine. Reconnected, then started a wash cycle so I could test the supply to it, which was fine too.
Then the bloody machine went through the cycle as normal with no problems! So it’s working again!
Bad connection maybe, or it was just having a bad day and wanted to take the p… out of me 😆
Drain pump is starting to get rather noisy, so that will get replaced next week hopefully.
Anyway, thank you for your help. Much appreciated.
