Hello.
The door lock on the machine does not lock when you close the door and select a programe.but if you then open the door and close it ,it locks and the machine will start the programe.
At the finish the door will not unlock.I have changed the lock but it is just the same.
Any help on this matter please.
Thank you.
i have had this before. i removed the plastic cover that is a heat shield for the drier, without this it will get very hot when drying so be warned. it should work ok once removed, officially you may have to change complete door
