Hotpoint WD420 error?
  • #34663
    aqua_serve
    Guys,
    I’m hoping that one of you may be able to offer me somew advice. I went to look at a Hotpoint WD420 that had died on the customer. The machine literally does nothing, the only life that I can see is that some of the leds onthe front panel light up for a split second when the machine is plugged in.
    The leds that lit are as follows
    Left hand side, top to bottom…
    Drying/High Heat (On)
    Reduce Creases (On)
    Rinse Hold (On)
    Timer Save (On)
    Extra Rinse (Off)
    The other leds on the panel left to right……….
    Door Lock (Off)
    Wash (Off)
    Rinse & Spin (Off)
    Final Spin (Off)
    Dry (On)
    On/Off (On)
    As mentioned the leds light for a fraction of a second. The customer reported that the machine had suffered some damage in transit and needed a replacement control board.
    I’ve removed the PCB but haven’t noticed any burn out. Would I be right in thinking that if it is the PCB then I’ll not be able to do anything for the customer and it’ll be a job for the Hotpoint boys?
    Many thanks,
    Mark
    #243520
    helo_75
    try taking off the display board, and refitting it
    sometimes, people press them too hard, and the buttons become dislodged
    other than that, its the main pcb and eprom
