Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › Hotpoint WD420 error code lights 3 + 4 flashing
- This topic has 7 replies, 3 voices, and was last updated 12 years, 10 months ago by
brucie.
June 18, 2013 at 6:08 pm #75901
brucie
ParticipantHi There
My Hotpoint Aquarius WD420 is not working. When I start a wash the on/off light flashes quickly and then lights 3 (Rinse Hold)& 4 (Time Saver) flash.
Have searched for this on the forums but can’t find the error code. Can anyone help with the error code and what might be wrong.
Thanks Bruce
June 18, 2013 at 6:37 pm #396534iadom
ModeratorRe: Hotpoint WD420 error code
How hard did you look, its under Help & Advice, Fault Codes. 😉
THIS is the page you want. 🙂
It is pointing towards a wash ntc fault, all wiring connections from ntc to main circuit board first thing to check, with the mains plug removed of course.
June 18, 2013 at 6:39 pm #396535Martin
ParticipantRe: Hotpoint WD420 error code
NTC (heater thermistor) fault I think?
June 18, 2013 at 7:25 pm #396536brucie
ParticipantRe: Hotpoint WD420 error code lights 3 + 4 flashing
Is there a guide on how to find this and how to check it.I’ve had a look here but couldn’t find anything.
http://www.ukwhitegoods.co.uk/help/fix- … dryer.html
Cheers Bruce
June 18, 2013 at 8:07 pm #396537iadom
ModeratorRe: Hotpoint WD420 error code lights 3 + 4 flashing
Worth having a quick read of THIS
Rules 4 & 5 are relevant. 😉
We cannot go into blow by blow instructions of every single repair . 😥
June 18, 2013 at 8:30 pm #396538brucie
Cheers for the advice.
I have found the thermistor and got it out. With a multimeter I am getting a reading of approx 90 -100 ohms before and after dipping it in hot water. Is there a reading for a good one.
Cheers Bruce
June 18, 2013 at 8:36 pm #396539iadom
The wash ntc should read 20k ohms at 20C. If it doesn’t vary when immersed in hot water then it could well be faulty, do check the wiring carefully, it is pretty flimsy.
Sent from my iPad using Tapatalk HDJune 18, 2013 at 9:07 pm #396540iadom
The wash ntc is not available as a separate part, only comes with new heater. 😥
Unless you have a local repair shop you could buy a second hand one from.
I have quite a few recovered from faulty heaters that are perfectly serviceable.
