Re: Hotpoint WD420 error codes ? Flashing lights.. help!
I have deleted your other post, no need to post the same question in other threads, it can lead to confusion. 😉
Neons 1+2.
F12, communication error. One PCB is not on speaking terms with the other. Could just be loose connections or a fault in either display or control module.
You may have disturbed something.
If machine is under 5 years old, your parts are free, you only have to pay the labour charge.
