Hotpoint WD420 Error F08
  • #46148
    johnnyhoz
    Hi all
    Went to the above today the on/off together with drying high heat lights were flashing which is light 1
    the known error codes points to the heater relay.
    Is this relay part of the main module ? and is it repairable by EMW ?
    John
    #288390
    Re: Hotpoint WD420 Error F08
    Yes, part of the main board. If you have a scrap board you could try changing the relay yourself. You can identify which one by tracing the wires from the heater.
    #288391
    johnnyj
    Could be the wash heater down to earth or pressure switch, i tend to find most of them are heater to be honest, jj
    #288392
    johnnyhoz
    Thanks Phidom
    I havn’t got a scrap board so I guess I need to find out if EMW can help
    I’ll give them a ring tomorrow
    John
    #288393
    It could be the relay but I have replaced relays on Merloni modules with only limited success. (Works well on Zanussi’s though!).
    I expect this
    RS
    is the relay you would need.
    Mike.
