Motor/Taco Fault.
Put this machine on spin and it will whip into spin then cut out. It will try it again a couple more times and then display F02 fault.
I have a reading through taco and checked all wires from taco/motor to board. No obvious signs on board apart from slight discolouration on track by connector plug from the taco.
Is the taco coil available as a seperate part?
Or is this a board fault?
Could be the magnet inside the tacho’s split or badly chipped, or has unscrewed itself so it’s not turning. The tacho/magnet isn’t available separately, I usually find a blown motor and nick them from it.
