Hotpoint WD420 Flashing Lights
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Hotpoint WD420 Flashing Lights
  • #27165
    choddyholder
    Just tried doing a wash and the On/Off light flashes along with left hand side lights 3 & 4 (rinse hold & time saver). As it’s doing this the machine is taking in water as usual but instead of filling up the machine, it just goes straight out of the hose at the back. This eventually stops and the lights remain flashing
    W E I R D
    This has happened before, and a straight switch off at the mains usually fixes it, but not this time…
    Anyone else had this?
    #212868
    Re: Hotpoint WD420 Flashing Lights
    Fault code is F03 or NTC fault. The NTC ( temperature control device) may be faulty, it could be loose connections or more likely the main control board could be at fault.
    choddyholder
    Great thanks for speedy response……
    Engineer callout then…..
    Matt
