hotpoint wd420 long cycle
  • #85974
    slyp98
    hi all this one takes 2 hrs to do a fast wash ? anyone , its heating the water and the brushes are fine
    #429928
    Re: hotpoint wd420 long cycle
    Syphoning, poor fill, OOB, customer error??
    Have you actually timed it yourself? I had exactly the same complaint on a WD420 only last week. checked everything out, set it to a 40 degree wash and it took 1hr 45 mins which is the time stated in the manual, not had a call back since.
    #429929
    slyp98
    No just cutomer feedback , ill go and set it up myself to avoid repeat thanks
    #429930
    slyp98
    iadom wrote:Syphoning, poor fill, OOB, customer error??
    Timed it today 2 hrs 10 mins for a fast wash, I also checked element all seemed ok , but after 8 mins the power dropped off at the element , nothing there so the water got to maybe 15 degrees fast wash should hit 30 I checked the dial on the program panel that’s ok set at 40 , then I checked the ntc and it reads 15 k ohms at between 10 and 15 degrees Celsius , I don’t have any info on this one anyone know if that is correct resistance , element checks out ok also 38 ohms thanks
    Sent from my HTC One mini 2 using Tapatalk
    #429931
    Not at home ATM, will have a look later or PM me an email address and I will send you the manual when I get home this evening.
    slyp98
    #429933
    I have no idea what that last post is about?
    I have checked and I have your email from 2011, still not home yet , will check if the manual has the thermistor ratings and if so send it to you. I would suspect that if the heater feed is cutting out like that it is more likely to be a pcb failure than the ntc?
    #429934
    slyp98
    Must have hit the post button 2ice cheers
    #429935
    Manual sent just now. 🙂
    #429936
    slyp98
    Cheers
