Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Hotpoint WD420 one shot failures
- This topic has 13 replies, 8 voices, and was last updated 20 years, 1 month ago by
iadom.
March 6, 2006 at 10:44 am #16125
ModeratorQuestion for the Hotpoint bods. 🙂
I have just been to inspect a WD420 for a, no dryer heat, fault. ( also had one on Friday with dryer one shot failed)
The one I saw this morning is just over 15 months old and is covered by a Norwich Union household policy. Norwich Union have sent a firm from Stockport (DASA member 😥 ) begins with a ‘P’ 😉 .
They have been three or four times in past few weeks, fitted three cut outs, and changed the control module. The longest the machine has worked in the past few months is for two weeks. Last week it worked for 30 minutes after the last repair visit.
On inspection this morning the TOC had failed again. The machine is as clean as a whistle, no blockages, fan OK etc. The only fault I could see was a kinked grey outlet pipe.Is there a known problem/fix for this failure.
And which design idiot decided to fix the cut out fixing screws from inside the heater box, absolute stupidity. 👿
March 6, 2006 at 11:30 am #167622Gertrude
ParticipantRe: Hotpoint WD420 one shot failures
If happening after a wash perhaps the kinked drain hose was not allowing the water to drain from the clothes efficiently thus creating overheating within the drum.
You’ve probably thought of that, anyway.
March 6, 2006 at 6:07 pm #167623iadom
ModeratorRe: Hotpoint WD420 one shot failures
For future reference should anyone else have this problem, a little bird 😉 has informed me that there is a modified heater box assy that is supposed to cure this fault, hopefully. 🙂
Part number is 1605230.
March 6, 2006 at 6:20 pm #167624Dales-Electronic
Jim – Ive just been out to one of these today is it the 1605160 one shot 160C button stat that fits inside the heater box with terminals outside??
March 6, 2006 at 6:28 pm #167625iadom
Thats the one, just had a look on Partfinder and it lists the later heater box, different element, fluff filter and a filter hose ❓ done away with, also the machine now has a 3 way fill valve instead of a 4 way valve. You just isolate the unused valve. No changes to the electronics are required.
Changed as from date code 40.
March 6, 2006 at 8:34 pm #167626johnnyj
The reason the one shot screws in from the inside is so force you have to split heater box and check for fluff build up, you are correct Iamdom they have changed the heater done away with filter removed the valve also the one shot has changed to a higher rating i usualy just convert the whole lot with the 1605230 heat box all the changes in one go.
March 6, 2006 at 8:40 pm #167627iadom
Has it reduced the incidence of this fault johnnyj ?
March 6, 2006 at 8:48 pm #167628johnnyj
Yes i’ve never had a failure on one i’ve done had a couple on machines that already had the the latest fitted on production but thats been caused by a loose fan on the dryer motor causing it to jam, all in all it’s doesnt give much prob’s at all.
October 5, 2006 at 12:33 pm #167629Martin
johnnyj wrote:The reason the one shot screws in from the inside is so force you have to split heater box and check for fluff build up
Whilst I understand the logic of them fitting the one-shot TOC on the inside, but I cannot figure what the modification (1605230) is meant to alleviate? After all it appears the new mod still includes a 160 degree one shot? If users don’t allow the usual 10 mins cool-down, it’s gonna blow anyway, modified or not surely? Why can’t they use a manual reset one anyway? 😕
I must get hold of a WD420 service manual I reckon? :rolls:
….I still can’t figure at what point the hot valve is supposed to work? On a WD420 I went to today, I set it on a Whites 95 degree wash and it just filled with cold water..weird??? 🙁
October 5, 2006 at 2:21 pm #167630Bryan
Martin wrote:
….I still can’t figure at what point the hot valve is supposed to work? On a WD420 I went to today, I set it on a Whites 95 degree wash and it just filled with cold water..weird??? 🙁Don`t want to go off topic here but funnily enough I was working on an Indesit WD12S yesterday and I was also slightly confused that it never called for hot water on any programme :?.
Thought it may have had something to do with the fact that there was no load in the drum :con:.
Bryan
October 5, 2006 at 4:39 pm #167631wilf
first one of these we sold the customer insisted it was faulty as it never took hot water. we checked ,it didnt ,then changed it for a tricity.
they must have had a lot of hot valves to get rid of!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
wilf :rolls:
October 5, 2006 at 7:07 pm #167632Flyman
Put it on a hot wash and it will pre-fill with cold water, it will then pause before filling to wash level with cold water. If the clothes are absorbent enough to drop the water level enough for it to do a top up fill it will use the hot valve. So they are not lying when they sell it as a hot and cold fill machine! Why they bother I do not know. 😕
New heater box uses the Indesit curly element as the original was breaking loose from the support bracket and causing noise and vibration. The filter has been removed so no need for the extra valve which was used to flush the filter clean. 🙂October 6, 2006 at 6:53 pm #167633Martin
Much appreciated Flyman for that info, very good thanks! 😉
February 5, 2007 at 7:12 pm #167634iadom
Just to update this thread, the modified heater box listed above is no longer available, the new parts number is 1605710. however it is reported that pre date code 54 machines need eeprom reprogramme if this part is fitted. 😥
Jim. -
